Установил 4.12. В начале wi-fi работал так же как и на предыдущем, потом пропал.
- Позывной: UA6158SWL
Сообщение GenaRostov » 24 окт 2022, 14:00
GenaRostov
Сообщение IU4ALH » 24 окт 2022, 17:42
Very simple ... it is the SQUELCH function, (also present in the 4.1x version of Bernard Binns).
By pressing the SQLCH key you will see that the volume bar changes both as an indication and as a color, in the part of the frequency display appears a numerical value -from 0 -to 50 and the word squelch; using the encoder you can adjust this value in order to cancel the audio for noise and for low intensity signals (which you decide which ones not to hear by setting the value ..) In practice it is a silencer that allows you to listen to only stations of one determined intensity up, resetting those that arrive lower than the set value. (I hope it was clear ...) To try .... tune in any station on any range that reaches you 7 - 8 as snr; press SQLCH: start from the value 0 and turn the encoder until the station is silenced; press SQLCH again to close ........ You will see that now, when you tune in, you will only listen to stations with signals above that snr value. it is the same as the squelch for VHF-UHF amateur radio FM emissions ... only here it is applied to all ranges and all modes. Remember that very loud FM stations ... exceeding 9 + 40 ... 9 + 50 ... are not muted.
IU4ALH
Сообщение kvadro23 » 27 окт 2022, 19:47
Господин IU4ALH ». У меня в прошивке следующий глюк : при маленькой скорости вращения энкодера всё работает , при большой скорости наблюдаются пропуски и даже зависание . Пробовал на механическом и оптическом энкодере , одинаково . Переключится на 10 или на 100 доли частоты нет никакой возможности . Это у меня так или это дефект ?
kvadro23
Сообщение IU4ALH » 28 окт 2022, 20:41
No ... it's not a defect ... it happened to me with a slightly dated ESP32 that can't manage to drink the WIFI connection .... check that on the sketch at the line:kvadro23 писал(а): ↑27 окт 2022, 19:47<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">Signor IU4ALH." </font><font style="vertical-align: inherit;">Ho il seguente problema tecnico nel firmware: a una bassa velocità di rotazione dell'encoder, tutto funziona, ad alta velocità si osservano lacune e persino blocchi. </font><font style="vertical-align: inherit;">Provato su un encoder meccanico e ottico, lo stesso. </font><font style="vertical-align: inherit;">Non c'è modo di passare a 10 o 100 parti della frequenza. </font><font style="vertical-align: inherit;">Sono io o è un difetto?</font></font>
#define WEATHER_UPDATE_MILLISECONDS 120000 ..... there must be no double slashes //, if there are, you have to remove them ....
Let me know
IU4ALH
kvadro23
Сообщение IU4ALH » 29 окт 2022, 00:05
Also try the other versions that are on my github .... see if they are okay ...
I'm sorry I can't do anything else for you.
IU4ALH
Сообщение kvadro23 » 29 окт 2022, 04:46
Уважаемый IU4ALH ! Очень красочная и неповторимая прошивка , как жаль что этот маленький казус портит все её прелести . Может как ни будь попадётся мне более свежая ESP . Спасибо ВАМ за заботу и поддержку .
kvadro23
- Позывной: R4PY
Сообщение Wlad66 » 31 окт 2022, 09:16
Всех приветствую! Попался в руки АТС-100.. При попытке прошить его прошивой 4.12 по методу Карпелянского и описанному здесь-загрузчик уходит сразу в стоп. Ком порт определился, винда 8.1.. Что я могу делать не так?
Wlad66
Сообщение Binns » 31 окт 2022, 11:23
Wlad66, Что значит загрузчик уходит в стоп? Скриншоты сделайте, пожалуйста. И так же можете попробовать программу для загрузки другой версии. На сайте на странице загрузки есть для вин 7.
- Позывной: R4PY
Сообщение Wlad66 » 31 окт 2022, 11:51
Скрин только вечером.. Забиваю бин-овские файлы в загрузчик, нажимаю старт-тут же коричневое окно стоп выходит
Wlad66
